04-21-2017 03:21 PM
I do believe I've sometimes been conflating this thread with the other longer-running one related to AO galvo control I linked back in msg 3. The other thread needs AI and the triggering-related needs are different too. Let me regroup and clear my head here.
I have no solid ideas about the distortion of your AO signal. Do all cycles look pretty much the same like that?
I'd revert to some very basic troubleshooting to test the behavior of AO all by itself. One thing that's intriguing is that the amount of extra time seems to correspond to the reduced slope. Extrapolating the initial slope would seem to terminate in time for the next trigger, as expected. It almost looks like there's been a step change reduction in AO sample rate part way through the ramp, though I have no working theory how & why that would happen. I doubt that's the true explanation, but the correspondence feels like some kind of clue.
Looking back at the recently linked code "MWE_RetriggeringDifferentAO - KPmod.vi", I do see something I missed before. The call to DAQmx Write should happen while the task is stopped, *NOT* right after it's started. I'm a little surprised in retrospect that it doesn't error out when the task is started before any data has been written to the task buffer.
It's possible you can accomplish this by *removing* DAQmx Start and setting the auto start input True on DAQmx Write.vi However, I'm not fully sure whether this interacts efficiently with the pre-loop "commit". So the alternative would be to perform DAQmx Write immediately after DAQmx Stop.
-Kevin P
