11-22-2014 06:20 PM
Hello Everyone,
I am acquiring and generating some analog signals on an NI-USB 6351 using DAQmx.
I am trying to retrigger an analog output signal using an analog input signal. I seem to be having some trouble trigger and retrigger the analog output signal from the analog input.
I've attempted to create a vi similar to ones I've found online but it doens't seem to be function quite right. I am fairly new to Labview and any help would be appreciated.
11-24-2014 02:50 PM
Hello there;
You mentioned it is not workingg properly.. do you get an overflow message or are just never receiving the trigger??
Cheers
