11-29-2014 10:19 PM
I am using NI 9219 module to read 3 analog inputs (2 current and 1 voltage). I have two VI's one for reading the current output from pressure transducers and one for thermocouple. When I run them simultaneously I get error relating to reserved resource and only of the data is read. How could I remove this error and get data from the the pressure transducers and thermocouple simultaneously. Thanks,
Ketki
Solved! Go to Solution.
11-29-2014 11:53 PM
12-01-2014 09:38 PM
Ok. Thanks ! I put them in a single task and was able to resole the error.
