I am using a PCI device in MAX. It recently went unnoticed in MAX, but it showed up in the device manager. I saw a couple posts that I should just delete the device. So I did that. That did not work, but now in my data Neighborhood, all the virtual channels associated with that device are gone.\
Is there any way to recover this? Or when I get the device to show up (different problem) in MAX will it automatically remember that information?
Have you tried reseating the device in the PCI slot? Does it show up in Device Manager and/or MAX after that? You may also want to update to the latest version of DAQmx.
If the device is recognized again in MAX, the channels previously should show back up, unless the MAX database has been corrupted or reset.
Hope this helps!
Austin H. Applications Engineering National Instruments
