Hello Karthik,
Thank you for contacting National Instruments. The digital input/output signals for the PCI 6036E default to the high state when no other value is being written to them. Internal to the board, there is a 50 KOhm pull-up resistor driving the line high. This can be overcome in two ways:
1) You can connect a 20 kOhm resistor from the terminal that you want to use to GND. This will cause the signal to be low until a voltage is applied to the digital line.
2) In your program, you can initialize the lines to a low state before any other code executes.
Try either of those methods to initialize the line states to low. If you have any further questions on this issue, let me know.
Scott R.
Applications Engineer,
National Instr
uments
Scott Romine
Course Development Engineer
