Multifunction DAQ
Read analog trigger signal gated by digital pause trigger
Hi!
I want to use and analog trigger together with digital pause trigger. At the same time i want to see on the scope the analog trigger signal which was gated by gate signal. Is it possible? Can i somehow wire the gated trigger to one of the outputs of the board?
Thanks in advance.
(3,831 Views)
 Hi Sergei_phys,
Thank you for the forum post!
I have a few questions about your post:
What hardware are you using? Is it NI or 3rd party? You mention using a scope, is that a NI piece of hardware/module?
In theory you can have a analog trigger to start the acquisition and a digital trigger to pause , but it depends of the hardware.
DanC12
(3,736 Views)
