I'm using the NI PCI-6036E card, and I want to read two of the analogue channels.
I do the AI config and AI start for the two channels right after eachother in a flat sequence struct. I use device "1" for both but the first Ai config gets "AI Channel 00" and the second gets "AI Channel 01". The Task IDs is saved in local variables but they are both the same value, the last one. The AI Read is placed in the main while loop.
How do I configure the VI to read two channels on the same device?
Best regards
/Crister Nilsson
