Hi Sammi,
The DAQPad-6020E (BNC) is designed for convenient measurement of up to eight differential channels using BNC connectors and cabling. In certain situations, however, it may be desirable to increase the channel count beyond eight. In this case, you must use one of the single-ended measurement modes (RSE or NRSE) with the DAQPad-6020E (BNC). Up to 16 (ch0 to ch15) single-ended channels are available in the single-ended measurement configuration.
Single-ended measurement modes require changing the source type switch (S0 through S7) settings. Figure C-1 in the User Manual shows the ground-referenced resistor switch settings.
Actually the BNC connectors on the front are connected to differential channel pairs, so the BNC called ACH0 is actually
connected to ACH0 and ACH8. Therefore, if you want to do single-ended measurements, each BNC connector is giving access to the "+" terminal of two channels (ACHx and ACHx+8). Depending on your choice of referencing, the ground point of the signal should be connected to the AISENSE (for NRSE) or AIGND (for RSE) pin.
There are different overvoltage protection specifications depending on the input type. The analog inputs (AI) are protected up to +/-35V when powered on (+/-25V when off). The Vcc value you is referring to the digital 5V, but the analog inputs are not referring to this value.
Hope this gets you started.
Philip C.
Applications Engineer
- Philip Courtois, Thinkbot Solutions
