Multifunction DAQ
PyDAQmx and USB-6000/USB-TC01 Thermocouple Device
Hi All,
I have a project I'm working on which requires reading values from a circuit board.
Need to do these things:
1). Read five analog values from test points on a circuit board with USB-6000 DAQ Unit.
2). Read tachometer from fan with a counter from USB-6000 DAQ Unit.
3). Read a temperature value from USB-TC01 Thermocouple Unit.
We can't use LabVIEW because we would need to recode our entire python low-level driver to interface with the software. Instead, I want to utilize PyDAQmx module to interface with the NIDAQmx driver.
However, I'm not sure how to use the functions in PyDAQmx to utilize reading values from the boards and units. Any help would be appreciated, thanks!
Best,
Jacob
Message 1 of 27
(7,225 Views)
I'm not sure why you would be asking how to to use PyDAQmx here. A quick Google turns up http://pythonhosted.org/PyDAQmx/usage.html.
Message 2 of 27
(7,220 Views)
I've looked into that website, and into the GitHub source code - there doesn't seem to be much information/documentation about compatibility with the USB-TC01 Thermocouple Device. I'm looking to interface all this hardware together, but there isn't a "how-to" guide.
Edited for clarity
Message 3 of 27
(7,215 Views)
Edited for clarity
That's what happens when you use open source software. You get what you pay for.
Message 4 of 27
(7,212 Views)
My assumption was that if the USB-TC01 Thermocouple Device uses the NIDAQmx 9.9 drivers, it should have compatibility within the PyDAQmx module since its a full interface to the NIDAQmx drivers.
Message 5 of 27
(7,209 Views)
Go with your assumption. No one is stopping you.
Message 6 of 27
(7,203 Views)
The device IS supported by DAQmx.
Message 7 of 27
(7,200 Views)
Either help contribute, or don't reply. I'm not looking for passive-agressive answers - this goes to nyc
Message 8 of 27
(7,197 Views)
Dennis,
I essentially want to use a method that would read the value of the thermocouple, and print the value when I type "T"
For instance:
while True:
print "Commands"
print "T    --> Read current Thermocouple Temperature"
print "FON --> Fan  On"
x = raw_input("Enter Command:")
if x == "FON":
    fan1.write_fan_duty_cycle(100)
Message 9 of 27
(7,191 Views)
Message 10 of 27
(7,177 Views)
