Multifunction DAQ
PXIe 6363 analog input Query
I have to acquire Differential(8) and NRSE(16)  analog inputs using one PXIE 6363. I am confused which type of configuration in labview program is required to achive this using NI daqmx VIs. I have attached two ways of configuration of blockdiagrams which might match to my requirement. Kindly help me which one is correct configuration
Thanks and Regards
Naveen
(4,383 Views)
Accepted by topic author rg.naveen
The bottom one in type2 appears correct.
(4,356 Views)
Thank you Dennis
(4,330 Views)
