Hi!
I'm working with a PXI-6251 Multifunction DAQ and had a question about the analog output capabilities.
We want to use the DAQ board to trigger an external relay. We currently have a 12 V input 1400 ohm relay, which the DAQ board cannot trigger as it can output only 10V maximum (is this correct?)
However, another we are looking at is switched at 5 volt DC, 139Ω. The DAQ board would be able to provide the voltage; but those specs imply a 36mA input current. The DAQ board specs state that the output current drive is only +/- 5mA, with an overdrive current of 20 mA - both these seem somewhat low. Am I misunderstanding the specifications or can the board only provide a maximum 5 mA @ 10 V? And would it be able to trigger this relay?
Thanks!
