Multifunction DAQ
PXI 6071E and PXI 4472 Analog Input Synchronization
My System : PXI-8186, PXI-4472 1EA, PXI-6071E 2EA, LabVIEW 7.1, NI-DAQmx 7.2
I want 4472 and 6071E AI Synchronization using DAQmx version... like http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B8C1DA7151524E2EE034080020E74861&p_node=DZ52007&p_submitted=N&p_rank=&p_answer=&p_source=External
I try to this method using \examples\DAQmx\Synchronization\Multi-Device.llb
But don't success by serival error.
Please post example that DSA and MIO synchronization using DAQmx version.
Thanks.
(2,340 Views)
Greetings,
Unfortunately, it appears that the exact example you are looking for does not exist on National Instrument's website. However, the following example synchronizes multiple PXI-4472s with NI-DAQmx:
PXI 4472 Synchronize and Stream to Disk
You may want to consider modifying this example to synchronize the PXI-4472 and PXI-6071Es in the same manner as the Traditional NI-DAQ example you referenced (divide-down the PXI-4472's Master Clock Timebase to obtain the sample clock for the PXI-6071Es, etc.)
Good luck with your application.
Spencer S.
(2,340 Views)
