11-11-2015 03:26 AM
Hi all,
i have to work on an old machine but i have some problem to understand the pinout of this. My system is composed by the board PCI-MIO-16E-4 connected to a adapter NI 183139B-01 so i can exit with a ribbon flat that reach a SC-2050 shield. I don't understand the pinout:
I have seen by the datasheet that the PCI have a pinout as in the image1 but in the SC-2050 this is change as image2. Where the pins are swapped? In the adapter?
11-12-2015 05:30 AM
Hi ypkdani,
it looks like the pins are swappend in the adapter. If the adapter is compatible with the board then you should just worry about the pinout of the SC-2050. Did you try it out? Do you read it correctly?
11-12-2015 08:33 AM
No i have search the schematics of the adapter but i didn't find anything
11-12-2015 09:25 AM
But did you try connecting a signal and reading it from LabVIEW or MAX? Do you read anything?
11-12-2015 10:48 AM
11-13-2015 01:25 AM
Thanks!! i will check this.
