I am using a PCI-MI0-16XE-50 which is failing the self-test in MAX 3.1.1.3004. I have used the E Series Diagnostic Utility which gives the error "Error 10809 occurred at cwdaq: Starting DAQ operation Attempted to start a pulse width measurement with the pulse in the phase to be measured (e.g., high phase for high-level gating)." Windows XP detects the device fine, as does MAX. The obvious answer is that the device is broken, but is it feasible or economical to have the device repaired? What tends to cause this type of problem and/or how can it be corrected?
You will need to contact National Instruments for a quote for repairing
you board. If you bought less than a year ago, it may still be under
warranty in which case it would not cost you anything to repair.
However, I would suggest in case you need to pay for repair to consider
getting one of the new improved and more performent yet low cost M Series devices.
Hope this helps.
