I need to generate a constant output voltage using a PCI 6722 analog output card. The card is connected to a CB-68 LP connector block using RC68-68 cable. I am able to see my PCI 6722 device in MAX. However, when I go to Test panels in MAX, I am not able to change the output voltage using the slider. If I move the output voltage slider to anywhere between -10 and 10 V, the multimeter still reads 1.74 V. In other words, the actual output voltage read by the multimeter does not correspond to what I want. I am using Windows XP Serive Pack 1 on a Dell Pentium 3 machine.
