NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Wagdy
PCI 6221 not visible by XP virtual mode
 Hi there, I have a problem with my PCI 6221 card. I have a computer with win 7 installed in it. Due to some labview compatibility issues I had to install XP virtual machine mode. My LV application is working but I have a problem with PCI 6221 card. Windows 7 can see the PCI 6221 card (using Automation & Measurement tool), but window CP mode doesn't see it. I installed the DAQmx 9.3 and 9.4 with no success to fix it.
Active Participant
PackersFan
Re: PCI 6221 not visible by XP virtual mode
This doesn't surprise me at all.
Your virtual machine software would somehow have to forward/share the PCI port with your virtual machine.  I've never seen this capability before.  Many VM applications will forward/share USB devices and optical drives, but that's all I've seen.
I guess I'm not certain, but pretty sure you're out of luck.
What were the compatibility issues you were dealing with?
Chris
Certified LabVIEW Developer
Member
Wagdy
Thanks Kudos for your reply. Will I have few complex LV applications that were developed using LV 8.5 for windows XP 32 bit. We had to upgrade to more powerful computer with Win 7 and additional RAM (you know that XP doesn't give you more than ~ 3 GB). I installed the run time engines needed and NIDAQ but I was never able to get it work properly. Final error I'm seeing is " Labview can't find Process myfile.exe". Basically it can't find itself when I try to open that application itself. If you hit OK it will open the program but I it doesn't work and thru a punch of VIs that can't load..You get the idea...?
Active Participant
PackersFan
Gotcha.  Yeah, I don't imagine 8.5 would work very well on a Windows 7 computer.
Chris
Member
Jason_L1
Wagdy,
If I am understanding the events presented so far correctly, you have developed your code using XP and have moved it over to Windows 7, but since you have been getting errors when you run your executable in Windows 7, you have been trying to get it to work on a VM on Windows 7 reverting back to Windows XP. Do you mind posting a screenshot of the error code you are getting? I would also verify that you are building your application correctly.
Jason L.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
