Im trying to read analog voltages through a PCi-6221 card using DAQmx. I have two inputs, AI0 is reading a signals from a signal generator (1Hz sine wave) and AI1 is reading a voltage which is output from the AO0 channel of the card. At the tbx-68 terminal I am reading the input voltages with a scope and they are correct, however, when trying to read through LV, im not reading the correct values. eg a sine wave @ 1Hz (0-2V) reads as -2.68 to -2.8 Volts.
Same problem with reading the analog output voltage in the analog input channel. 0V ouput reads throught LV as a 10V, where reading at the terminal gives 0V (or whatever the voltage is).
Not sure what is happening or what I might be doing wrong in my setup so any advice is appreciated.
thanks,
David
Using
LV7.1
Daqmx 7.3
