I have intalled a PCI-6220 in a rack mounted PC, and it is not detected by OS and not listed in M&A.
Config :
- Industrial PC :
- P4 2Ghz
- 512 DDRAM
- 4 PCI slots, and 9 (S)PCI slots behind a bridge.
- Windows XP SP2
- NI-DAQ 7.4
All PC slots are empty, I have tried to install the PCI-6220 in each PCI and SPCI slots, and it was never detected except ONE time in the SPCI4 slot : The "New hardware Wizard" detected the board but was unable to install the driver, I installed it manualy (chosing the PCI-6220 found in the list), then all seem to be ok, but ...
In M&A, the board property was not good (no IRQ for exemple, ...) and the autotest or reset of the board fail.
After removing, then re-inserting the board in the SPCI4 slot it is no more detected at all (I tried several times).
Any idea ?
Thanks in advance.
Jean-Francois LAROCHE
