From what you just described, it sounds like you are using Test Panels to measure the levels of your AI without anything connected to them. This is common behavior because the inputs are floating in a high impedance state. Any current that passes through the high impedance state will appear as high potential on that signal.
Knowledgebase 332957KD talks about this behavior.
If you are sure that you are connecting and measuring the appropriate analog input signal to ground, but still the railed signal, then it could be a case that there is a problem with the input amplifier. If you have all three devices installed, make sure that you are connecting t
he same device to ground as you are measuring in Test Panels. Then post back to this discussion with exactly what you are doing so we can make sure that there's nothing that we are missing.
Also, you can run the
E Series Diagnositc Utility on your device to see if there's any problems.
Let me know how things work out.
Jared A
