Multifunction DAQ
PCI-6032E Testing
Hi Folks,
I have a used PCI-6032E running in an external PCI card cage next to a PCIe-6353. The 6353 works fine, no problems. The 6032E was a used card and has never been used in anger. It's hooked up to a CB-68LP, it's configured. I can run the self test and it returns a pass.I can run the self calibrate, and it seems to work. I run up the test panel and set all of port 0 to input, they all come up high. I connect the input pins to GND and they a come low, but float high again after.
I note that Pin 8 doesn't seem to have 5v on it, neither does 14. It seems to 250mV mush on it. I tried hooking up the counters, if I set the counter to 20MHz Timebase it runs nicely in the test panel, it I set it to PFI 5 and tap it to the CAL terminal on my scope I get nothing.
Does this sound right and I've missed something, or does this sound like it has a fried input/output driver?
Message 1 of 1
(2,111 Views)
