03-18-2015 04:16 AM
I want to order a case structure with a digital square wave in the case selector and the program will be run automatically, instead of using a push button, I will like to show some examples.
03-18-2015 06:12 AM
Case case structure will not take a boolean waveform. It can take single boolean values. So if you read your digital signal one bit at a time, you can use the case structure.
What exactly are you trying to accomplish here?
03-18-2015 11:08 AM - edited 03-18-2015 11:18 AM
I want to execute a loop in 1 second then a second loop for 1 second and that's repeatedbefore pressing the button stops.
