With my NI card I have to control a laser scanning head, I need three AO
channes for the x,y and z axes and the fourth AO or a GP channel for PWM signal
that gives the laser output power. What I've done is to use the WFM functions
to load and to start my waveforms from a buffer. I had to create 4 different
buffers, one for each channel, and then to mix them toghether (multiplexing) to
be able to get out the 4 signals simultaneously. Otherwise I would have to send
4 couples of WFM_Load(Channel#) and WFM_Configure(Start) in sequence, but this
would cause a start lag time to each other. With this card I can't load the 4 AOs with
different buffers and letting them start at the same time, the AO_Configure(mode) works only for the
AO commands, no
t for WFMs. I'd also need to start the PWM signal before to output
the other 3 signals, and to change its DutyCycle and Frequency when
I decide to move the x,y,z axes and then to change them again when axes stop.
The CWPulse command that comes with Measurement Studio gives a flexible PWM out from
GPCTR_OUT1, but at the moment I had to put all the 4 waveforms (x,y,z and PWM) in the
same multiplexed buffer for sycro purpose.
Am I working properly with this card, or should I approach in a differnt way?
Thanks, Marco
