Multifunction DAQ
No proper signal with NI-4351 card
I am trying to use a NI-4351 for temperature  measurement (together with TX-68T connector block). However, I don't get a proper signal in our laboratory. Using the MaX  and looking at  the test panel: there is sometimes the right voltage but most of the time  the signal is noisy or even more than that: it is jumping to the maximum and minimum of the voltage range (for every voltage range).
In an another building with another supply circuit the signal is okay. So we suppose an EMC problem: Together with the Elec. department we have disconnected all "critical" consumers- no change, also filtering the supply of the PC has no effect.
Can you propose a special supply voltage filter? The noise frequency is very low (less than 1 Hz). Other lab cards and electronic devices work properly under the same conditions. Has anyone ever had this kind of problem? Any solutions?
Thank you.
Bernhard
Message 1 of 8
(3,409 Views)
have you checked, if the camera is changing the channels  during the acquisition.?
Message 2 of 8
(3,389 Views)
?? Sorry, which camera?
Message 3 of 8
(3,384 Views)
sorry for my confusing answer,
please exchange camera with board Smiley Wink
Message 4 of 8
(3,382 Views)
okay, but I don't know how to do it. Is there any possbility to do this in the MAX? Or can I access the card directly (without MAX?)? Or do I have to check hardware pins? Because at the moment I am using 2 virtual channels to make a readout in LabView and these virtual channels are not representing a real hardware information.
Bernhard
Message 5 of 8
(3,378 Views)
sorry for my incomplete answer;
some 4351 boards have the problem  changing the channel during measurement,
because of this you get these incorrect values
Message 6 of 8
(3,375 Views)
I don't want to bother, but if a understand well: sending the card back to NI and asking for a new one could be a solution?
Message 7 of 8
(3,372 Views)
this could be an option,
but first please test, if this could be the error
e.g. connecting known signal to the ports, and the processing the measurement
Message 8 of 8
(3,354 Views)
