Multifunction DAQ
Ni-USB-6009 digital imput for Monarch optical sensor
I am trying to input diagital data from Monarch optical sensor to NI-USB-6009 DAQ.
So far I am only able to see True or False from signalexpress after connecting the optical sensor, how can I make it show RPM?
Here is the manual of the therometer: http://www.monarchinstrument.com/pdfs/1071-4849-110R_ROLS24-W.pdf
(4,345 Views)
Could you specify on which pins you are connecting your optical sensor?
(4,309 Views)
I am connecting signal input to PFI 0 which is the counter now.
(4,305 Views)
What I understand from the operating instructions of your optical sensor, it outputs a TRUE value every time the object does a revolution. So by measuring the amount of times it outputs a TRUE value in one minute you will be able to determine the RPM. On signal express you will only be able to see the signal but not the RPM value. If you want to do that I would recommend to create a LV VI that can detect the change of values of your sensor and then count the amount of time the sensor outputs a TRUE value. That way you can compute the RPM.
(4,284 Views)
It seems the only way can make it work.
I have tried counter port on the DAQ PFI, it was able to read the counting up of number, and that is all it could do.
I am thinking to buy an individual display for the optical sensor, which can help me to make my life easier instead of getting into world of Labview.
Thanks for your replies Inachosa!
(4,279 Views)
Sure you are welcome. If you find that easier go for it!
(4,269 Views)
