Hey Slicked,
It sounds like you are just trying to get started with using Global Channels or Tasks in NI-DAQmx. You can find much more information by going to
Help > MAX Help and searching for 'global channel'. Doing that will then direct you to the DAQ Assistant Help which can be found by opening MAX and going to
Help > Help Topics > NI-DAQmx > DAQ Assistant. You can type in 'global channel' there and you will find much more information than I can possibly relate in a post.
Since this sounds like your first time using the Global Channels or Tasks I will give you a quick 'how to':
- Open Measurement and Automation Explorer (MAX)
- Expand the My System tree so that you can see Data Neighborhood
- Right click on Data Neighborhood and select Create New...
- Select either a NI-DAQmx Global Channel or a NI-DAQmx Task*
- Choose which type of channel and which physical channel you want to use
- Click Finish and Test the channel to make sure everything works
- You can then use the Task or Channel in LabVIEW by using a DAQmx Task Name Control or a DAQmx Global Channel Control (found in the Controls > All Controls > I/O > NI-DAQmx subpalette)
For more details make sure to check out the help file mentioned above.
*The difference between a Global Channel and a Task is that a Global Channel does not have any timing or sampling information related to it.
Best of luck getting your system up and running,
