10-15-2014 06:08 AM
Hi!
I have 3 modules NI 9234 and 4 channels (distributed through the 3 modules) did not answer anymore. Which channel corresponds to an accelerometer installed in a stay of a cable-stayed bridge. Some of the accelerometers are located approximately 200 meters from the cDAQ-9188.
I tested the different channels of the modules and I verified that no power is supplied to the sensor (the output voltage is 0) and apparently the amplifier is working normally.
So, I would like to ask the fowling questions:
Thank you very much for your attention!
10-16-2014 04:48 AM
Hello Brosandi,
The lightning conductor could be the source of your problem.
- Have you tried to connect another C Serie Module on you chassis to test if it's the cDAQ (D Sub) or the C Serie Module which got an issue?
- The repair cost depends of the Hardware involved.
If you want a suitable hardware for your environment, please contact the sales department. They will advise you.
Kind regards.
