Hello to all,
My Systems:
System 1
PCI-6221 M series card
LabVIEW 7.1 Express
Code developed using MX environment
WinXP
System 2
AT-MIO-16E-2 Card
LabVIEW 7.1 Express
So far do not see MX as an option (ran "default" install with this card)
WinXP
Here is my issue and 2 questions:
I installed a PCI-6221 M series card in a customer's PC. I am running the newest versions of LabVIEW Express (7.1) with WinXP. I used the standard LabVIEW installation to develop their code on that PC, including the M-Series disk. They now have a running application that is not quite complete. That system is in a different state. I need to go there and update some code in a few days, and I would like to develop that code at home, then port it to their machine. I have another computer at home. On it is installed an AT-MIO-16E-2. I have so far ran the standard LabVIEW Express (7.1) development system installation. Of course LabVIEW is smart enough to sense what kind of card I have and installed the appropriate software for that card, which I believe means that MX is NOT installed.
MY QUESTIONS?
1. Can I use DAQmx with AT-MIO-16E-2 and then port the code (with minor modifications) to the other machine?
2. What do I need to manually install on my machine with the AT-MIO-16E-2 card to enable this?
I thought I read that you can run MX on older boards by installing a patch. But I also need to know what software to install from the LabVIEW disks.
Many thanks for all your help,
Max
