Multifunction DAQ
National Instruments USB-6008 - Wrong input reading
I am trying to use USB-6008 to read from Kistler Type 5073A charge amplifier, which is converting the charge generated by Kistler type 9317b force sensor.
I can directly see the signal using ManuWare software, connected via COM port to the amplifier and see that the Voltage is ~0 on all inputs.
Since I need to have more control of the readings and logging data. I want to be able to use Matlab. But when reading through the NI USB-6008 there is an offset on all inputs (+2 Volts).
When I received the equipment there were two extra wires connected to the DAQ to the Amplifier. Which I have disconnected. Is it possible that they were used to 'synchronize' the ground on the DAQ and the Amplifier?
(2,336 Views)
My first thought was that you need the GND of the amplifier going to AI_GND.  If that is missing, you will get offset errors like you are stating.  You might also want to give this article a good read: Field Wiring and Noise Considerations for Analog Signals
GCentral
(2,296 Views)
