Using NIDAQ 6.9.3 downloaded from NI site. Installs the drivers but does not install the documents. If I run the docsetup.msi it gives the option to select documents and tries to install them, but cannot find the PDF's. I am left with links to non-existent documents from the Start menu. Any suggestions (other than downloading them individually from the NI site)?
Other than downloading a previous or later version of NI DAQ from the NI website, then next suggestion would be to download the documents individually from the ni website.
Also how are you installing NI DAQ (If from cd have you tried copying the contents from the cd on to the hard disk and then trying to install it.
I cannot use a later version of NI-DAQ as it does not support the DAQCard-700. I don't think I can use an earlier version as I am using WinX. I was trying to avoid the hassle of downloading manually.
NIDAQ 6.9.3 was downloaded from the NI site, as that is the only place I have been able to get it from. Installation was from HDD as per the instructions.
