I try to calibrate my strain gages.
My set-up is as follows:
- strain gage
- NI9945
- RJ50 cable
- NI9237
- cRIO9024 (DAQmx driver is installed, see Figure 1)
and LabVIEW 2014 installed
I would like to start with a calibration in MAX as described in: http://www.ni.com/tutorial/7130/en/
Unfortunately I am not able to create an "NI-DAQmx Global Virtual Channel"... (see Figure 2, 3)
At the same time I have programmed the FPGA to gather data with the NI9237.
This works without any problem and thus the connection, the cRIO, the module are fine. It shoud be kind of a driver-issue..?!?
Thanks for the help in advance,
Ruud
