I am using a NI9205 module with spring terminals configured for single ended inputs. The inputs are measurement signals from current transducers and so I need to connect a burden resistor between each input and ground, as per the diagram attached. Can anyone recommend a neat way of installing the burden resistors for this application?
Mark
