12-23-2012 08:11 AM
12-26-2012 07:15 AM
Hello Heliliano,
According to the link below, your MatLAB version is compatible with NI myDAQ.
http://www.mathworks.com/products/daq/supported/ni-daqmx.html#myDAQ
Which version of NI DAQmx driver do you have in your computer? In order to try to fix this issue, you can try to install the last NI DAQmx version.
http://joule.ni.com/nidu/cds/view/p/id/3622/lang/pt
If this solution does not work, let me know.
12-26-2012 09:38 AM
Hi Plínio,
Thanks for your prompt response. Are you brazilian? Below, in portuguese, I can explain better the situation.
Eu já havia verificado o link dizendo que o MatLab R2012b é compatível com a NI myDAQ, mas mesmo assim, não encontro o modelo NI myDAQ na lista de modelos de cartões National Instruments, para configurar minha aplicação nos blocos de E/S Analógica do MatLab/Simulink.
Meu driver está atualizado com a última versão.
Se você estiver no Brasil, seria muito útil se pudermos conversar por telefone.
Muito obrigado,
Heliliano
12-26-2012 10:08 AM
10-16-2013 03:31 AM
Hello.. I tried installing all the drivers starting from daqmx9.6.1 to elvis4.3 but still it doesnt show up in matlan in list of installed adaptors. And one more question, is mydaq compatible to student version matlab only??
09-22-2016 08:00 AM
Hello, i am from indonesian..
I have checked the link that says that Matlab R2012b compatible with NI myDAQ, but still does not meet NI myDAQ models in the list of National Instrument card model to configure my application in packs Analog I / O MatLab / Simulink.
can you help me.. I was working on my thesis project 😞
03-16-2017 05:51 AM - edited 03-16-2017 05:52 AM
Could you find the answer if myDAQ is working in Simulink? Since I am still struggling with this.
Regards.
03-16-2017 07:38 AM
Heys, guys.
Did you refer to the link below in MathWorks Requirements and Third-Party Requirements session?
https://www.mathworks.com/hardware-support/nidaqmx.html
Ensure you have all support packages installed and you are with the right version of MatLab installed.
