Multifunction DAQ
Reply
NI myDAQ and Matlab R2012b Simulink
Highlighted
How do I communicate NI myDAQ card with Matlab Simulink?
At the Simulink RTWin Analog Input (mask of Real-Time Windows Target analog input) have no options for Install new board like my "National Instruments myDAQ"
I'm using Matlab R2012b version.
Heliliano
Message 1 of 8 (1,969 Views)
Reply
Re: NI myDAQ and Matlab R2012b Simulink
Hello Heliliano,
According to the link below, your MatLAB version is compatible with NI myDAQ.
http://www.mathworks.com/products/daq/supported/ni-daqmx.html#myDAQ
Which version of NI DAQmx driver do you have in your computer? In order to try to fix this issue, you can try to install the last NI DAQmx version.
http://joule.ni.com/nidu/cds/view/p/id/3622/lang/pt
If this solution does not work, let me know.
Plínio Costa
Application Engineer
National Instruments Brazil
Message 2 of 8 (1,949 Views)
Reply
Hi Plínio,
Thanks for your prompt response. Are you brazilian? Below, in portuguese, I can explain better the situation.
Eu já havia verificado o link dizendo que o MatLab R2012b é compatível com a NI myDAQ, mas mesmo assim, não encontro o modelo NI myDAQ na lista de modelos de cartões National Instruments, para configurar minha aplicação nos blocos de E/S Analógica do MatLab/Simulink.
Meu driver está atualizado com a última versão.
Se você estiver no Brasil, seria muito útil se pudermos conversar por telefone.
Muito obrigado,
Heliliano
Message 3 of 8 (1,944 Views)
Reply
Olá Heliliano,
Sim, eu estou no Brasil. Você pode ligar no nosso suporte.
(011) 3149-3149 opção 3
Cordialmente,
Plínio Costa
Message 4 of 8 (1,939 Views)
Reply
Hello.. I tried installing all the drivers starting from daqmx9.6.1 to elvis4.3 but still it doesnt show up in matlan in list of installed adaptors. And one more question, is mydaq compatible to student version matlab only??
Message 5 of 8 (1,365 Views)
Reply
Hello, i am from indonesian..
I have checked the link that says that Matlab R2012b compatible with NI myDAQ, but still does not meet NI myDAQ models in the list of National Instrument card model to configure my application in packs Analog I / O MatLab / Simulink.
can you help me.. I was working on my thesis project Smiley Sad
Message 6 of 8 (402 Views)
Reply
[ Edited ]
Could you find the answer if myDAQ is working in Simulink? Since I am still struggling with this.
Regards.
Message 7 of 8 (36 Views)
Reply
Heys, guys.
Did you refer to the link below in MathWorks Requirements and Third-Party Requirements session?
https://www.mathworks.com/hardware-support/nidaqmx.html
Ensure you have all support packages installed and you are with the right version of MatLab installed.
https://www.mathworks.com/matlabcentral/fileexchange/45086-data-acquisition-toolbox-support-package-...
Plínio Costa
Message 8 of 8 (30 Views)
Reply
