Multifunction DAQ
NI USB-X 6353 AO 0 generates signal unintentionally
Yesterday, while I was working with NI USB-X 6353, I realized that the analog output channel 0 generates voltage reluctantly. When I reseted the device, it started generating signal immediately again, even if I do not run any vi. I checked the other 3 AO channels and I see that they do not show the same behaviour. It is a weird situation I think. Is it a default feature for the AO 0 for this daq? If it is not, what could be the problem with the device?
Egemen
Message 1 of 10
(5,003 Views)
Hi newbieeng,
I was checking the datasheet of this specific device and this is not a common behaviour. Before I can help can you please answer the following questions:
-What were you doing when the problem occured?
-Where the device working properly before?
-What is the hardware/software setup?
-What is the output voltage from AO 0 that you are getting? (This is to see if there is noise).
Also just as a test, can you create a task in NI MAX for this AO 0 to create a specific wave to see if the extra voltage appears.
Jordan
Message 2 of 10
(4,972 Views)
Hi jred101,
-I was running a vi which generates finite analog voltage with the amplitude of +5V for 1.2 ms (416.67 Hz, 5V, %50 duty cycle, duration: 2.3 ms). I attached the vi for the check.
-Before me, there is someone was using it, however, it is not possible to contact with him. SO I do not know the previous behaviour of it.
-I use NI USB-X 6353 AO 0 channel connected a transistor which is connected to spark plug driver (ignition coil pack) to spark. There is no problem is detected for the connections in terms of hardware. As a software, I use Labview 2012 v12.0 with Win 7 SP1.
-I will measure it as soon as I get the device on tomorrow.
-I will check it with NI MAX too.
Thanks in advance.
Egemen
Message 3 of 10
(4,958 Views)
Hi jred101,
I have just measured the analog output signal after opening the device with the same device analog input channel 0 (I wired AO + to AI 0 + and AO 0 GND to AO -). The left signal is measured from AI 1 without the AO generation, the right one indicates the case AO generation exists (+5V). It seems that AO 0 does not respond the vis. I attached the VIs that I got these images.
P.S. I could not find the multimeter in our lab, that's why I use the device for measurements.
Egemen
Message 4 of 10
(4,943 Views)
Hi newbieeng,
I saw the result from attachments in the previous posts and it clearly shows the extra voltage. To make sure can you please send me a screenshot of the configuation you used for the Continous Input VI. Additionally, can you please try the same physical connections as before, but instead of using LabVIEW use the Test Panel from the NI MAX and send the screenshot as well. This is just as second reference to see if behaviour of this output.
 Jordan
Message 5 of 10
(4,925 Views)
Hi jred101,
I am sending what you wanted to me below. Sorry for the delay.
The configuration of the "Continuous Input VI":
NI-MAX Test Panel screenshot:
Egemen
Message 6 of 10
(4,887 Views)
Hi jred101,
Yesterday, I was running the device for generation voltage from AO 2 & 3 (one pulse, 50% duty cycle, amplitude: 5V -from 5V to 0V-, frequency:416.67 Hz, time: 0.0023 s -the same signal in the third post-), I realized that AO 2 stopped but AO 3 did not. I thought there is the same problem for the AO 3 channel.
Egemen
Message 7 of 10
(4,867 Views)
Do you have back EMF supression across that ignition coil? If not, that could be what looks like is making your AO hardware to fail.
-AK2DM
Message 8 of 10
(4,855 Views)
Hi newbieeng,
I was looking at the Test Panel screenchot you sent me and I can't see the extra 5v, the changes in voltages are extremely small and seems as regular noise. I strongly recommend you to use the Test Panel again, ucnheck the auto-scale box and change the scale of the graph to check. If you keep seeing the an odd behaviour the next step would be call NI support to proceed with an RMA.
Message 9 of 10
(4,847 Views)
Hello AK2DM,
I do not about the ignition coil too much and also about circuits. I am not familiar with electric/electronics stuff 😕 Do you mean "electromagnetic field" with EMF?
Hi jred101,
I did as you said, you can see the screenshot below. Unfortunately, there is nothing changes 😕 I think there is a program with AO 0.
Egemen
Message 10 of 10
(4,824 Views)
