Multifunction DAQ
NI USB-9161 carrier and NI 9215
I have NI USB-9161 carrier and NI 9215 and I can't connect them using max. So I have looked and It seems that I need to use old DAQ base drivers.
I downloaded that old drivers and Used DAQ Base list devices, it finds my card. Then I want to create task but I cant select my device..
Any suggestions?
Thanks in advice
(4,140 Views)
Dear pawhan11,
Could you give us more info about the OS you are using? Could you also give us more info about the DAQ Mx Base Version? Maybe there is a case of incompatibility between your OS and DAQ Mx Base interface.
Also, aren't you able to address your device by name? (manually enter Dev1/ai1 , for example)?
Izabela
(4,091 Views)
