11-12-2014 04:58 AM
Hello. I have NI USB 6361 board and I want to write C program (I use Embarcadero C++ Builder) for acquiring analog data from this board (a0 channel). I connect signal generator to ao channel.
I read documentation and examples for my board. My program allows to acquire data, but I have one problem.
I can see waveform, but values of data are differs from data, that I acquired from board with Measurement Studio. I acquired data and export this to Excel, and find min and max values. Signal acquired with Measurement Studio have stable values for max and min. But my program give me different values and I dont know why.
Can anybody expect my C code and help me? I attached my code below. Excuse me for my Enlgish and thanks for help.
float64 max,min,value; int32 points,written,error; char errBuff[2048]={'\0'}; char *channel; wchar_t *ch; int i=0; TVarRec args[1] = {0}; max = StrToFloat(EditAOMaxValue->Text); if (max>10.0) { max = 10.0; EditAOMaxValue->Text = "10,0"; } min = StrToFloat(EditAOMinValue->Text); if (min<-10.0) { min = -10.0; EditAOMinValue->Text = "-10,0"; } value = StrToFloat(EditAOValue->Text); if (value>10.0) value = 10.0; if (value<-10.0) value = -10.0; args[0] = value; EditAOValue->Text = Format("%1.1f",args,0); points = StrToInt(EditAOPoints->Text); for(;i<points;i++) data[i] = value; //5.0*(double)i/points; ch = ("Dev1/"+ ComboBoxAOChan->Items->Strings[ComboBoxAOChan->ItemIndex]).t_str(); channel = AnsiString(ch).c_str(); // DAQmx Configure Code DAQmxErrChk (DAQmxCreateTask("",&taskHandle)); DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,channel,"",min,max,DAQmx_Val_Volts,NULL)); DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,points)); // DAQmx Write Code DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,points,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL)); // DAQmx Start Code DAQmxErrChk (DAQmxStartTask(taskHandle)); // DAQmx Wait Code DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle,10.0)); args[0] = written; LblStatus->Caption = Sysutils::Format("Status: written %d points\n",args,0); Error: if( taskHandle!=0 ) { // DAQmx Stop Code DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); } if( DAQmxFailed(error) ) { DAQmxGetExtendedErrorInfo(errBuff,2048); args[0] = errBuff; ShowMessage(Sysutils::Format("DAQmx Error: %s\n",args,0)); }
11-13-2014 07:57 AM
Hello Skyer,
Just so that I understand, does the exact some code give you different results between the two development environments?
Also, this code appears to only output values. How are you reading these values back in?
11-13-2014 11:48 PM
Hello OlliesCamel,
I'm sorry, but I posted the wrong code. Below my code for acquiring analog data in finite mode.
float64 max,min; int32 points,mode,read,error; char errBuff[2048]={'\0'}; char* channel; wchar_t *ch; int i=0; TVarRec args[1] = {0}; char* sample; char* buf; fprintf(LogFile,"Calibtrating...\n"); max = StrToFloat(EditAIMaxValue->Text); if (max>10.0) { max = 10.0; EditAIMaxValue->Text = "10,0"; } min = StrToFloat(EditAIMinValue->Text); if (min<-10.0) { min = -10.0; EditAIMinValue->Text = "-10,0"; } switch (ComboBoxAIMode->ItemIndex) { case 0: mode = DAQmx_Val_Diff; case 1: mode = DAQmx_Val_RSE; case 2: mode = DAQmx_Val_NRSE; default: mode = DAQmx_Val_Cfg_Default; } points = StrToInt(EditAIPoints->Text); ch = ("Dev1/"+ ComboBoxAIChan->Items->Strings[ComboBoxAIChan->ItemIndex]).t_str(); channel = AnsiString(ch).c_str(); // DAQmx Configure Code DAQmxErrChk (DAQmxCreateTask("",&taskHandle)); DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,channel,"",mode ,min,max,DAQmx_Val_Volts,NULL)); DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",100000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,points)); // DAQmx Start Code DAQmxErrChk (DAQmxStartTask(taskHandle)); // DAQmx Read Code DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,points,10.0,DAQmx_Val_GroupByChannel,data,points,&read,NULL)); max = -30.0; min = 30.0; args[0] = read; LblStatus->Caption = Sysutils::Format("Status: read %d points\n",args,0); for (i = 0; i < read; i++) { args[0] = data[i]; Memo1->Lines->Add(IntToStr(i)+" "+Format("%2.4f",args,0)); sample = StrFmt(buf,"%2.4f \n",args,0); Series1->AddXY(i,data[i],"",clBlue); if (data[i]>max) { max = data[i];} if (data[i]<min) { min = data[i];} } args[0] = max; LblMaxValue->Caption = "Max value = " + Format("%2.4f",args,0)+ " V"; args[0] = min; LblMinValue->Caption = "Min value = " + Format("%2.4f",args,0)+ " V"; Error: if( taskHandle!=0 ) { // DAQmx Stop Code DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); } if( DAQmxFailed(error) ) { DAQmxGetExtendedErrorInfo(errBuff,2048); args[0] = errBuff; ShowMessage(Sysutils::Format("DAQmx Error: %s\n",args,0)); } fclose (LogFile);
11-14-2014 10:10 AM - edited 11-14-2014 10:11 AM
How do you know that the Measurement Studio values are the correct values?
Which language are you using with Measurement Studio?
11-14-2014 10:46 AM
Skyer,
11-17-2014 12:06 AM
1) No, I use single development enviroment - Embarcadero RAD Studio C++ Builder.
2) I connected waveform generator to board. And I know values from generator. Also I use oscilloscope to check the signal.
11-18-2014 10:23 AM
Maybe I'm missing something, but how are you using Measurement Studio, if you aren't using the Visual Studio IDE? Are we talking about the same product?: http://www.ni.com/mstudio/
11-18-2014 02:13 PM
You mentioned Measurement Studio in your first post.
Yet you now say you are using Embarcadero RAD Studio C++ Builder.
Which is right?
It seems you are confused.
