11-14-2014 05:26 AM
Hi ,
i am very new to labview and DAQ functions. i would like to generate two analog signals on a0 and a1, sine waves on each analog outputs to be exact . it works fine if i use only one port but to use the second port its throwing an error . should i be using an array to get the signals to each port ? please find the attached screenshot
or should use a second DAQ assist to get the signal on a1 ?
Please help
Jacob
11-14-2014 06:37 AM
You should be able to configure the DAQ Assistant to output both signals. Yes, you can have multiple channels in a single task. Use the Merge Signals to combine the two sets of data into a single line for the DAQ Assistant.
