NI Home
Cart Cart | Help
You are here:
Reply
Member
PeSi
Re: NI USB 6009 pc connectivity issue
@Vermontbell: You are right. These two versions won't work together.
Your hijacking is forgiven :smileywink:
In theory it's a good idea to solve many people's problems at once.
But mostly people have different software-versions, different hardware, different applications and of course different computers.
So it is easier for us to track the issues in separated threads.
Peter
Member
Mirekal
@ Peter: My NIDAQmx version is 9.5.1 f1 and not 8.5.1. Sorry for this mistake.
You wrote : 1- Check if the "NI Device Loader" service is active.
I thought it was, because it appeared in the bar and is launched at restart.
The link you added is not ok for me and Firefox said "Firefox can't find server at ae.natinst.com." I've found this one "http://digital.ni.com/public.nsf/allkb/0819391CA91B3EB38625731D00024649?OpenDocument" which seems to be the same.
I've now understood what you meant by "Make the settings on the recovery-tab of the NI Device Loader Service"
This is the real key of the problem and it works better when I reboot the machine.
If NI MAX fails I know what to do in a few seconds! Great!
Thank you for your help.
Member
Joel_G
Hi All,
A few points on this matter;
External USB hubs are not officially supported by NI or any of NIs USB devices, however, they often work with no problems. That said if you're going to use one I would strongly recommend using a powered one, I wouldn't be surprised if an unpowered one gave you problems.
Mireka and Ajeetraj, thanks for your posts, I think your two problems are different and unrelated, Ajeetraj's device disconnects while running, but Mirekal's device will continue running fine once it's connected. Mirekal; please bring your problem up in another thread and make sure you mention that you've already tried the solution from this KB as this is the first thing people will suggest.
Ajeetraj, what PC are you using specifically, and which chipsets does it have?
Many Thanks,
Kind Regards,
Joel G
Applications Engineer
National Instruments UK & Ireland
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
