Hi there,
I have encountered a problem on configuring the NI USB-6008 device. The NI-DAQmx ver 8.3 is installed in a Windows XP.
Error:
The device self test has failed. The error repot from the device driver is as follows:
Error -88302 occurred at Self Test
Possible Reason(s):
An internal error occurred.
The error above came up when it comes to self test.The LED light on the device is blinking non-stop. When I right clicked on the device in MAX, "Test Panels", "Delete", "Properties" and "Self-Calibrate" option are not available. The same error will come up if "Reset Device" is clicked. I have looked for the solutions in the forum but I can't get to the configuration settings as mentioned in this solution: http://digital.ni.com/public.nsf/websearch/19E7993CF8366EED8625764200771C68?opendocument&Submitted&&...
Is there any other ways to solve the error?
