New NI-SCOPE user. Does NI-SCOPE offer th functionality to automatically record wave forms (create references) and data (values for excel) on a pre-defined interval?
The NI-VISA is a driver for our scopes and digitizers. While it does offer the soft front panel that looks and acts like a normal scope interface, you cannot set up recording or automatic measurements with it.
In order to save the measurements, I would recommend using LabVIEW or LabWindows/CVI with using the NI-SCOPE drivers to save the data as you can also analyze your data at the same time.
Justin M. Applications Engineering National Instruments
