10-01-2015 02:40 PM
I am having difficulty getting a proper voltage reading on my 6341 Analog inputs. The inputs seem to show values that don't correspond with that I expect, and the DAQ also seems to force the external voltages low, even when the inputs are all set to tri-state.
When reading with the RSE configuration (because that is how our hardware is set up), I only see an increasing voltage that increases to a random asymptote. On other configurations, the voltage may be decreasing, or stuck at a single level (that doesn't correspond with the measured value)
Are there any solutions I could try in this situation?
Billy Maier
10-02-2015 12:01 PM
I am having a similar issue with a 6210. Voltage readings that shouldn't be and read values shifting towards an asymptote (-10.6V for me). I am also using RSE mode. Not helpful I know, but at least you are not alone.
10-02-2015 12:43 PM
