02-04-2016 01:38 PM
02-07-2016 04:26 PM
It sounds like it may be due to the way you are hooking them up together. How are you connecting them?
I assume that your strain gauge sends analog voltage to the board. Are you using a BNC cable to connect the DAQ device? Are you using the same cable to connect the two in your test setups as well as the final setup? Are you sure that the cable you’re using to connect the two is functioning properly?
02-09-2016 01:01 PM
I am using the saem BNC cables during the final test and the initial two test setups. I even read the analog voltage at the pins on the NIDAQ Board, which were correct. Basically something is happening when the signal gets sent to the computer but only when I use my strain gauge. DO you have any other ideas of what could be wrong?
02-09-2016 04:12 PM
Do the voltage range of the DAQ and the sensor match? What is the voltage output range of your strain gauge sensor?
02-11-2016 02:41 PM
The manual for the board lsits the Input range to be ±10 V, ±5 V, ±2 V, ±1 V, ±0.5 V, ±0.2 V, ±0.1 V. My Strain gauge is outputting ±10 V, as it should be.
02-12-2016 11:12 AM
Can you post some pictures of your setup? Both of the two tests and one of the final setup where it's reading incorrecty.
Are you sure that you're grounding the signal coming from the strain gauge correctly? Not grounding it could produce erroneous voltages like you are seeing.
02-18-2016 10:56 PM
03-16-2016 12:31 PM
hey guys,
I can post pictures tomorrow. What exactly do you mean by grounding the strain gauge?
Also, how do I go about doing signal conitioning with this NIDAQ board? Or do I need to use a different DAQ?
Again, thank you for all the help!
03-17-2016 12:55 PM
I finally got the voltages to change when I deflect the strain guage with my hand! Hoever, the voltage still srops to 10.6 volts first. I am not quite sure why it does. When I try to zero it using my conditioning block, the read voltage refuses to budge. It flatlines at 10.6 Volts. Here are some pictures.
This is the strain gauge, a Transducer Techniques Thin Beam Sensor.
This is the conditioning block that it is attached to. The BNC Cable is coming out the top right and goes to the NIDAQ Board.
Here is the board. The BNC Cable goes to the top left, to pins 1 and 3. This connects to my laptop with a standard USB Cable.
Here is a screenshot of my test panel. I deflected the strain guge four times, each stronger than before, which can be seen in the voltage difference peaks. However, as you can see the zero is at 10.6 V. What can I do to fix that?
Thank you!
03-17-2016 04:35 PM
What do the cables at the bottom of your conditioning block plug into? Was that conditioning block used in the initial tests that you ran or is this an addition that you've added that has helped you get the detection of the deflection by the strain gauge.?
