05-12-2014 06:54 AM
Hello all,
I'm trying to record an acoustic signal in Dasylab 10.0.1 with the NI-DAQmx 6210.
System: Windows XP SP3
Board: NI-DAQmx 6210 with USB
MAX configuration:
Sampling rate: 32768
Samples: 32768
Connection: RSE
After an hour I received an error message:
NI-DAQmx Analog Input: AnalogIN_0-3
file: Modul_ad.c, row:2205
I already deleted the old and created a new task, but it didn't change anything. In addition I already tried to set the configurations back to factory settings and start up new.
Does anyone have the same problem or an idea to solve it?
Lars
05-13-2014 04:36 AM
here is Dominik from the AE's in Munich.
At first i want to know what DAQmx driver version you use. You can find the version in your MAX (Measurement & Automation Explorer).
Perhaps you can add a screenshot of your error message.
Thank you
Best regards
Dominik
05-13-2014 05:43 AM
Hello Dominik,
thanks for you reply. I'm useing the DAQmx 8.6.0f6 driver version. In addition I added an screenshot of the error message.
Best regards from Dortmund,
Lars
05-13-2014 06:07 AM
Hello Lars,
I found out that the USB-6210 needs the DAQmx 9.6 driver.
You can see it here:
http://www.ni.com/white-paper/6913/en/
Perhaps the problem is caused by the driver. Please try to deinstall your driver first then download the new driver and install it.
You can find the DAQmx 9.6 here :
http://www.ni.com/download/ni-daqmx-9.6/3423/en/
I hope it solves your problem.
Best regards
Dominik
07-23-2014 04:07 AM
Hello Dominik,
Sorry for late reply.
Finally I bought a new PC and updated the driver and software to the current version.
Thanks for you help and best regards,
Lars
