Multifunction DAQ
NI-DAQ + NI USB-4431: Error 233054
Hello everybody,
First of all, here is my config:
- Dev PC: Win 7 - 32 bits
- LabView 2009 - 32 bits
- NI DAQ 9.7.5
- Acquisition card: NI USB-4431
The problem:
When I start my application right after having plug my acquisition card to my PC (or after boot), the DAQ Assistant give me the error 233054:
I did not found any explaination on this amazing tool which is internet, so  I come here! 😉
The only way I fount to go forward, is opening NI-MAX, ask to do an acquisition, ask to do a generation (which one works) and then, I can go back in LabView and launch my program!
The problem seems coming from initialization. But I don't see what I have to do to have it working every time! Any idea?
Harold
(4,180 Views)
I found a corrective action request which documents this behavior as a bug in the driver setting an incorrect DDS clock rate. Try upgrading to the newest version of DAQmx and try again.
Best regards
(4,149 Views)
eloidi.k,
Will the newest DAQmx support LabVIEW 2009?  If not, can you check for a version that both corrects the CAR *and* still supports 2009 for sure?
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(4,128 Views)
Accepted by topic author haroldducept
I just check the compatibility between daqmx driver and labview. I notice your daqmx driver version 9.7.5 is not compatible with labview 2009, that why, you have this deal.
The latest version of daqmx with labview 2009 is 9.7 see below
DAQmx and LabVIEW Version Compatibility:
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
So may you uninstall 9.7.5 and reinstall daqmx 9.7 see this link
Uninstall Software
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Best regards.
(4,121 Views)
Hello everybody!
Thanks for your replies!
Unfortunately, I have to work on something else for the moment. So I will come back on this subject in a few days.
So, following your advices, I will uninstall my NI-DAQ version to install the 9.7 and come back here to tell you if it works!
Harold.
(4,105 Views)
Hello all,
As promised, I've followed your instructions and it seems it works!
Thanks a lot for your help! I would'nt have find it alone!
Harold.
(3,942 Views)
