Hi Dave,
There are a couple of forum postings dealing with this same issue.
http://forums.ni.com/ni/board/message?board.id=170&message.id=91569&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=250&message.id=6564&requireLogin=False
Both seem to provide the following steps as a possible solution.
"Complete the following steps to set up permission for the MAX\Data directory:
1) Browse to the C:\Program Files\National Instruments directory.
2) Right-click the MAX folder and select Properties.
3) Click the Security tab, and click the Add button. Type in the user name and click OK.
4) Give the user Read & Execute, List Folder Contents, and Read permissions.
5) Click Apply and then OK."
That should resolve any DAQ problems you're having with user accounts. Please let me know if you have any more problems with this.
Regards
Matthew Slaughter
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
