07-04-2016 09:40 AM
I am using a NI cDAQ-9188 with NI 9223, NI 9220 , NI 9237, NI 9235, NI 9214 .
When I run them using a NI-MAX version 15.3, they all work.
When I try to run them on a NI-MAX version 5.5 ,the NI 9223 module comes: "unsupported cDAQ module".
Is it because the NI-MAX version or is there any other reason?
Thank you.
07-05-2016 04:36 AM
Please see this link:
http://digital.ni.com/public.nsf/allkb/1A7587205357457A86257EAD0001DE7E
Your Daqmx Version 5.5 doesn't support your module.
kind regards,
Lily
07-06-2016 08:13 AM
The NI-MAX version doesn't matter so much, but the NI-DAQmx version does. (Within NI-MAX, the version of NI-DAQmx can be seen under My System→Software in the tree.)
If the installed version of NI-DAQmx doesn't support a module, it will appear as a "Unsupported Module" in MAX. As per http://www.ni.com/product-documentation/10622/en/, the NI 9223 with Screw Terminal requires at least NI-DAQmx 9.2, and the NI 9223 with BNC requires at least NI-DAQmx 9.9.
