08-07-2014 11:19 AM
08-07-2014 11:50 AM
Correct, I get a 5V signal when I attach it to our sensor undergoing tests. A multimeter and oscillscope recorded ~150mV during the same test. When the module has no input source wired in, LabVIEW essentially shows a 0V signal. I tried your battery test and LabVIEW recorded a signal nearly idential to that of a module without an input. I measured the voltage of the battery with a multimeter, and it read 1.5V. I have done a similar test in the past using a sine wave generator. In this scenario, I again recorded an amplified signal in LabVIEW compared to what my multimeter read. I do not recall the specific values, however.
08-07-2014 02:12 PM
08-07-2014 02:56 PM
Yes, the tests have been performed on multiple channels. The only issue with arranging an RMA is the fact that I am in the middle of an animal testing period, and I have been using and plan to continue to use the malfunctioning device. I am particularly interested a transfer function-like ratio of two sensors (output divided by the input). Therefore, as long as the malfunction affects the sensors identically (which is seems to be doing), our data is not greatly affected. Once the animal testing portion of my experiment concludes, I will look into submitting an RMA.
Thank you for your advice!
