07-27-2005 06:56 AM
07-27-2005 07:00 AM
I'am using XP!!
07-28-2005 10:47 AM
With the little information I have, to find the problem I will suggest you some tests :
- Remove the board and try to lauch MAX. Test the panel with another board if you have some. If you do not have others boards, you can simulate a device by rightclicking on DAQmx devices -> create a new DAQmx device -> simulated DAQmx device.
Test it.... Try in Labview to check if it works also. If this test passes, soft seems to work well. If not, uninstall and reinstall DAQ driver properly (configuration panel/add-remove programs...)
- plug the board in a slot, retry MAX when the PC is on. If it does not work, try on another slot. If the same behaviour appears, if you could test on another PC, it will be helpful to warranty that the board is out of order.
Thanks to let me informed.
Regards
David D.
Applicationj Engineer
France
