07-20-2005 12:05 PM
07-27-2005 10:54 AM
Just to be sure... did you explicitely set your DAQmx task to use differential input? The default configuration for AI is typically RSE (referenced single ended). If your software is set to use RSE and you wire your signal differentially, then you won't get good data. You can explicetly set the input signal configuration on the DAQmx Create Channel VI in LabVIEW.
-Sal
07-28-2005 02:57 AM
Hello Sal,
I changed from singled ended to differential the DAB configuration . I changed this via software aswell. I don´t know it doesn´t performe as it should ¿? Thank you very much for your help anyway.
Cheers
