I fiddled around quite some hours now with my new 6030E ( PCI-MIO-16XE-10 ).
I feel this is a terrific card with a myriad of possibilities, though a bit too slow ( 100 kS/s )and I may buy its much faster successor.
I need this one for building a Multi Channel Radiation Spectrum Analyzer ( for discerning alpha, beta and gamma particle and quanta radiation in its energy levels ).
My 6030E runs under LabView 7.1 and NI-DAQ 7.
In MAX my DAQ card passes all tests flawlessly.
In Labview I can run several Example .vi's ( as supplied in LabView Help/Examples/Hardware IO/Traditional DAQ etcetera.
I also can use the DAQ Assistant in all of its features.
Still 2 questions please :
1.
While running the example in LabView 7.1/Help/Examples/Hardware_I/O/Traditional_DAQ/General/ " Cont Acq&Chart (buffered ).vi " I fail in configuring the AI input for RSE.
It is default configured for Differential.
I altered the sub.vi " AI config.vi " ( which offers the choice in Differential/RSE/NRSE ) from default Differential into RSE, saved this (sub).vi, started the main.vi " Cont Acq&Chart (buffered).vi " anew but, whatever I try, the said .vi keeps the default " differential " input.
Obviously, I do oversee something.
What ?
2.
Having attached my signal source onto hardware AI channel #7, whatever I try, on the FP it doesn't make any difference which " channel # " I click ( left small up/down choice ) and in the righthand rolldown " channel " menu, nothing is in there ( blank, i.e. no channel choice at all).
What did I do wrong ?
Whichever channel I click ( AI 0/15 ), all channels respond in displaying the input sgnal while only channel AI #7 has an input signal.
BTW : in MAX both of my problems are not there.
In MAX/Testpanels I can choose the right AI input channel #7 whereas other channels do not respond ( is OK ).
Also, in MAX/Testpanels I can see my signal in RSE or Differential whatever I want.
So, my two problems are really confined to the " Cont Acq&Chart (buffered ).vi i.e. the sub.vi " AI config.vi ".
Please don't ask me why I prefer - in this case - RSE above Differential.
I do know the related pro's and cons.
I just want RSE for this application.
I have plenty of documentation on the E series in general and on the 6030E in particular, but I can't resolve my questions myself as yet.
Please realize I am a very beginner in NI-DAQ ( though, having some more experience in NI-GPIB & LabView which work very fine for me.
Thanks for any help
Peter van Daalen.
